JVC LCD doesn't display image from HTPC
Discussion in 'LCD & LED LCD TVs Forum' started by Furton, Jan 13, 2008.
Tags:
  1. Furton
    Furton
    Jan 13, 2008
    3
    Finally got my HTPC working and all I needed to do was connect it to JVC LT-32DS6bJ, which I thought would be the easy part. However I've gone through all the settings in the nVidia control panel and just can't get a picture on my LCD. the nVidia control panel detects the LCD tv, and every time I change a setting the LCD does flicker as to accept the changes, but I can't get a Vista desktop to display on it.
    Specs are
    AMD BE 2400
    2GB RAM
    Abit AN-M2HD
    I'm using the on-board HDMI connector on the board which has GeForce 7050 chipset built in.
    Any ideas or some tests I can do?
    The TV was bought back in 2005, will it be to old to connect to a HTPC?
  2. and36
    and36
    Apr 5, 2005
    285
    +13
    Hello Furton
    Can't help you on the hdmi front as my comp doesn't have this but I have my computer connected to my 32DS6 through vga but can only get a resolution of 1024x768 which is one of two stated resolutions in the manual, the other being 800x600 ( I think).Try doing a search on this forum as someone managed to get a higher resolution using powerpoint a year or so ago.
