DJBlade
Thanks, what hours have you changed your lamp at and could you notice dimming of the original lamp before changing and what was your thoughts on firing the PJ up with the new lamp fitted ?Hi Chaps
For reference purposes if anyone is in need of reassurance, here is a current brand new official JVC replacement bulb PK-L2615UG, supplied by Allan at Ideal AV and sourced direct from JVC.
Thanks Allan!
Sean
Had my lamp over a month now (direct from JVC via Allan) but not had time to fit it yet but I’m at 2800 hours (all on low lamp) and def notice dimming now for the last few hundred hours or so.
Def time to get it fitted !
