I received my JVC on Monday and installed it immediately. Installation was easy, two clips (ISO) and I was up and running. I had to swap the red and yellow around as the settings were being lost when the ignition was turned off.
The unit itself it brilliant. All the problems that have been mentioned on here with some giga mp3 players don't seem to effect the JVC.
The navigation of the folders and songs it simple and starighforward (without a screen). And the features are easily accessable.
The sound quality is awesome. I have running the standard front door speakers and two tweeters in the front windscreen struts.
In the rear I have two PYLE 6x9s and they have a new lease of life with this unit. Before I had a CDX??? Sony Head unit which pumped out 4x50w though with the added MOSFET amp on the JVC, it makes a huge difference. I was not aware until now just how much difference the MOSFET amps would make and was stunned when I had finally set the USER preferences and put in my DVD MP3 disk.
Got mine from Pixmania and at £188.90 all in, it was an absolute bargain.
HIGHLY RECOMMEND TO ANYONE
