JVC HV38 Banding on component input
Discussion in 'General TV Discussions Forum' started by charles, Dec 10, 2004.
  1. charles
    charles
    Jul 6, 2001
    1,360
    63
    norwich
    +176
    I have just purchased the above TV and apart from one small problem I am very pleased with its performance.
    Using the component,progressive scan output on my Denon 2910 DVD player into the sets component input I can see faint vertical transparent banding accross the whole screen.The bands are around half an inch apart.Accompanying this is a sporadic moire type patterning .Once again this is faint but noticeable.
    Using all other inputs both RGB scart from the DVD or Sky + and SVHS feeds the picture is fine.
    The cables being used are Ixos.
    Any ideas about what can be causing this problem and how it can be cleared.
    Many thanks
    Charles
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    turn PS off on denon and let JVC do the processing see if it helps.......
  3. peahead
    peahead
    Dec 14, 2002
    2,998
    St.helens
    +384
    I have the banding problem when useing the rgb scarts but not when useing component input does it happen when you use the rgb scart inputs on your tv. :confused:
