JVC HV36P38 £999 from Currys, How Good is it?
Discussion in 'General TV Discussions Forum' started by ayrshiredude, Jul 17, 2004.
  1. ayrshiredude
    ayrshiredude
    Feb 27, 2004
    193
    16
    Saltcoats
    Currys have the JVC HV36P38 once again for £999. Having had 5 RPTVs and had various problems with them I was wondering what this tv is like. Can anyone shed some light?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    That is very bloody cheap!!!!!!!!
    Nice 36" set a mate of mine is looking to buy one! but hasnt yet on paper it looks good! as long as quality is up to par no worries
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    saw it today in currys looks small for a 36", JVC brochure had 3 shelf stand i think and currys model had 2 (not sure if it is old stock as JVC did change their stands recently).
  4. cerebros
    cerebros
    Dec 27, 2002
    1,294
    48
    Leicester
    +29
    Yeah the QC's the only real worry - I'd have been ecstatic with my HV32P37, the model down from the 36" if the 1st 3 samples hadn't had really annoying geometry probs and the 4th hadn't died within 2 days (beginning to wish I'd just asked them to repair it and bring it back, 'cos geometry wise is was spot on apart from some slight curvature in 4:3 mode that I couldn't quite remove), as I got my money back (eventually) and I'm back to a 14" TV as main screen while i try to find a replacement :(
  5. jerkyboy
    jerkyboy
    I had a couple of P37's and they were stunning. The only problem was horizontal lines on RGB (I was not the only one).
    Hopefully the 36" does not suffer the same problems, if it does not then you will be very impressed.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    the 36 has has made in uk on it (which with electronics is always a worry (no offence john)) but compare to the phillips on display in currys not bad. and the old panny PB50 next to was looking not as sharp either, but the ZP38 tosh i think is my favourite, switched off at least!
    Unless you want to spring for a PD30 or SONY
