JVC HV28P37 or Sony 32FX68U?
Discussion in 'Televisions' started by mt50, Nov 18, 2004.
  1. mt50
    mt50
    Oct 24, 2002
    1,397
    stoke-on-trent
    +44
    HI, i'm looking at replacing my old 21inch sony TV with a widescreen tv now as it's for my bedroom i don't want to spend much. i am looking at around £400. so i've got it down to 2 tv's the JVC which has got componant inputs and is 28inch, or the sony which doesn't have componant but is 32inch.
    both are £400 but the sony may be a returned item not sure yet need to check it out. and the JVC comes with a 5 year warrenty.
    just got a couple of questions. does the JVC do 480P? as i've got a usa xbox so prog scan would be nice.
    would you beable to tell the difference from RGB to prog scan on a 28 inch TV or would i be best to go with th esony for the extra size?
    need some help or mini reviews n both tv's as i would like to buy one in about 2 weeks.
    thanks
  2. bigtired
    bigtired
    Nov 1, 2003
    160
    North Wales
    I have the Sony and am delighted with it. The alternative I looked at was a Loewe but plummed for the Sony in the end. There are loads of threads on here estolling the virtues of the Sony. Can't comment about the JVC.
    Regards
    Justin
  3. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    I have the 32FX68 and can confirm it is flippin' superb in every regard. Who the hell is selling it for £400??
    Bargain of the century at that price!
  4. peahead
    peahead
    Dec 14, 2002
    2,810
    St.helens
    +264
    Hi mt50 yes the jvc will take 480p and 1080i from a xbox i should now i have the 32" version of this tv and you will notice a difference from rgb. :thumbsup:
  5. 123orth
    123orth
    Nov 29, 2003
    263
    leeds
    i am keen for this sony set
    cheapest i have seen is close to 700£ ,where did u find this bargain for 400£
  6. mt50
    mt50
    Oct 24, 2002
    1,397
    stoke-on-trent
    +44
    hi, it's in my local argos in the clear out they are having. you don't get a stand with it though. and i think the are returned items but arn't sure as the boxes don't look like they have been opened they are just very dusty.
    still not sure which one to get :(
    32inch may be too big for my room but then if i get the 28inch tv i may which i'd have gone for the extra size after a while.
    really don't know what to do.
