jvc hv-32D40 vs. HV-32P37
Discussion in 'TVs' started by emfect, Dec 30, 2004.
  1. emfect
    emfect
    Hello,
    I am looking for the difference between the jvc hv-32p40(d40 in UK) and the HV-32P37S (which is a year older).
    It seems from the JVC website tech specs document (found here: http://www.jvc.nl/files/techspec/04jnl_television1.pdf) that the only difference is that the sound of the P40 is better and that it has 900i/75Hz instead of just plain 75Hz (whatever that means).
    Here in The Netherlands the P40 is 230 euros more expensive. Can anyone give me an argument why I should go for the P40 instead of it's predecessor besides of just wanting to have the newest model ;)
    Had the DIST technology been further improved with the P40 or is it the same as the P37?
    p.s. I know in the UK the D40 has an integrated DTV tuner, but in Europe that is not the case (that is why it's called the P40 I think).
    Thanks in advance for anyone that can shed some light on this!
  2. emfect
    emfect
    No one here knows anything about the difference in picture between these two tv's?
    (sorry bout the bump)
  3. boab_is
    boab_is
    The D40 model has a built in digital tuner in the UK, and a very slightly upgraded D.I.S.T. picture enhancement over the p37. other than that, essentially the same. If the D40 model is available at a similar price, it is a nicer looking set, so get that one
  4. supersonic87
    supersonic87
    Dec 31, 2003
    286
    Swansea, Wales
    the p40 is the d40 without a digital tuner and is not available in the uk, and can only be obtained by importing. i believe feature wise the p37 and p40 are similar.
  5. emfect
    emfect
    boab_is: Can I ask where you got the info from? Because I called JVC Holland and they say the only difference between the P37 and the P40 is the design (but the guy didn's seem too sure).
    Here in Holland the P40 is at least 120 pounds more expensive but if it indeed has a better version of D.I.S.T onboard (or better sound?) I think I'll get that one...
    Thanx for all the help!
  6. Bonex
    Bonex
    From what I know the 32D40 is only sold in the UK. The 32P40 (notice the D in the first and the P in the second model number) is sold in the rest of Europe. The D one has a digital tuner for digital terrestrial transmissions.
    If it can be of any help, the review of the 32P40 of an important Italian a/v magazine is better than that of the 32P37. They are basically the same tv (they have the same tube and all), but comparing the two reviews it seems that the D40 has better convergence/geometry. The P40 is probably a slightly improved model. They said the rgb connection is a lot better (even if not prefect) than the P37 (lot of noise) and didn't mention any compatibility issue with ntsc on the rgb (the P37 seems to be unable to show an ntsc signal properly on the rgb input).
    Hope this helps!
  7. Shadow_Zero
    Shadow_Zero
    Oct 3, 2003
    45
    Netherlands
    Can anyone verify now if the P40/D40 has better RGB support for NTSC?
    I'm looking into these 2 models myself now and wonder which to pick :)
  8. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    can these models really take 1080i and 720p?.......cuz that would rock man.
  9. funcky
    funcky
    Dec 12, 2005
    676
    28
    +28
    These models can display 1080i, but not 720p, so hd compatible but not hd ready (I think). In the UK the rgb outputs any 60hz sources in composite on the P37 and P40 unfortunatly, think it will apply to Holland as well, but don't quote me on this. If u have the money go for the newer model, but there is'nt much difference between them.
  10. Shadow_Zero
    Shadow_Zero
    Oct 3, 2003
    45
    Netherlands
    That's just too bad, why would they do that? :confused:
    I've heard some stories about bad NTSC and PAL60 RGB support with the tv over here as well, so I assume the models are pretty much the same.
    I also read it was improved with the P40, but if I hear you it's still not good...?
  11. Shadow_Zero
    Shadow_Zero
    Oct 3, 2003
    45
    Netherlands
    And can it display full/true 1080i high definition, or is there some downgrade process attached to that with?
