JVC HV-32D40, Horizontal lines, RGB !!!!!!
Discussion in 'General TV Discussions Forum' started by jerkyboy, Jun 27, 2004.
  1. jerkyboy
    jerkyboy
    Before I send this TV back, does anyone know of a cure for the horizontal lines problem via RGB.
    basically if I use anything via RGB, Xbox PS2 or DVD I am getting faint horizonatal lines about 1cm apart covering the whole screen.
    I returned 2 JVC P37's because of this fault and was hoping that JVC might have been bothered to sort this problem out.
    I am a bit gutted as the picture is really very good apart from these Fu***ng lines.
    Before anyone suggests it, yes I am using good acart leads.
  2. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    Have you contacted JVC about this? Have you tried using different scart cables (i.e. different makes).
    I'm afraid I am not too much help as I haven't decided yet on the HD40.
  3. peahead
    peahead
    Dec 14, 2002
    3,007
    St.helens
    +386
    why not use s-video or component instead rgb not that much better
  4. Digiman
    Digiman
    Dec 17, 2003
    367
    +17
    Jerkyboy, looking at your replaced TV's, quite a few seem to be RGB related problems. Does your scart(s) run near mains wires etc?
    What happened to your 36" JVC? Is that 9 then?
