JVC HV-32D40 - anyone got one?
Discussion in 'General TV Discussions Forum' started by howieeb, Aug 25, 2006.
  1. howieeb
    howieeb
    Apr 16, 2006
    828
    +17
    If so, I have some questions :)
    Has anyone tried using it with their 360? Does 1080i and 480p work ok at 60hz?
    Does this set scale all signals to 1080i, or display them as is?
    I also plan on using a NTSC GC, PS2 and a Wii (when they come out) at 480p via component. Some people have reported difficulties with NTSC and progressive scan on this set and i'm a little concerned.
    Cheers, H
  2. fallenangle
    fallenangle
    Oct 19, 2005
    404
    +23
    I've got another, I think, similar JVC model but don't have an XB360 so I can't answer that first one one but I believe the 'problems' with NTSC are similar. The TV doesn't give RGB through the RGB enabled SCART sockets when used with NTSC sources it defaults to composite for some reason.
    The prog scan trouble with the component connections is a minor issue some people have reported principally with DVD playback. A slow thin (blue?) line sometimes appears moving up or down the screen. I've never seen it on my TV.
