Jvc Hrs6700?
Discussion in 'Digital TV & Video Players & Recorders' started by stanleyntl, Aug 25, 2004.
Tags:
  1. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    How does the JVC HRS6700 SVHS VCR compare with the latest models? :rolleyes:
  2. Emerton
    Emerton
    May 19, 2004
    216
    Bedford
    +27
    Its about the same mate, Ive got this model, it has nothing special (ie, audio dub, insert edit) just basic but reasonable quality and reliable. It has SVHS 'ET' which allows you to record a high band signal onto standard tape, but it only shows an improvement if you're using good tapes anyway. I don't think I would pay over £100ish for one considering this is an old model.
