jvc hr-vsx30 multiregion- HELP!!
Discussion in 'TVs' started by drunkenmaster, Jan 25, 2005.
  1. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,567
    The Shaolin Temple
    +44
    Having connected the dvd/vcr combi via component leads and rgb scart to my pana 36pd30, the dvd picture is constantly jumping every two minutes or so. I have tried every possible setting on both player and tv(progressive and rgb) using region 1 and 2 discs.
    Is the player faulty or am i doing something absolutley wrong?. This has caused a dispute from the supplier (whom i shall not name at present)as they apparently find no fault and are not prepared to exchange the player.
    Problem is being disabled i am unable to try other component players and the distance to the shop is a mighty long way.
    Component leads prowire-. Fully wired rgb oxidised scart.
    The funny thing is that the discs play fine on my old wharefdale dvd player.
