JVC Head Unit - Stuck CD Tray
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Hawklan, Jan 17, 2005.
  1. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    The CD Tray in my JVC head unit is unresponsive to the point where I have a stuck CD in there
    Before it came totally stuck it was a bit slow in responding to the eject button. I thought maybe I had a dodgey CD so I tried another - But now the eject button is totally unresponsive and I have a CD stuck in there
    I've tried the usual things like pressing the reset button and disconecting the battery but no joy
    Instead of waiting for JVC to fix do any of you guys have any ideas
    Many thanks
    RON
  2. diesel_uk
    diesel_uk
    need to open unit up, Look to the right and you will see a white plastic cog.
    With small screwdriver ( flat) keep manually pushing cog up and the cd will eject.
    Your fault could be
    Belt loose
    cd cover/copy cd cover stuck
    objects in cd tray *money/rubbish**
    forceed cd inserting.
  3. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Hi Mate
    Thats for that - Since it's under warranty being only a couple of months old - I think I'm safer taking it back to the dealer and then of to JVC. ( I don't really want to take it apart)
    I can't see there being anything stuck in there or forced insertion so I guess it must be a fault
    Many thanks
    RON
  4. diesel_uk
    diesel_uk
    make sure the unit has nothing in. Otherwise expect a bil.
  5. JiMbOb_74
    JiMbOb_74
    Take it back to the shop and ask for a refund or a different make.JVC are very unreliable... take my word for it.buy something by Sony,Panasonic,Pioneer or Alpine.
    Remember buy cheap,buy twice...
  6. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Well the unit is with JVC now - I refund was not in the offering as I'd had the unit for a couple of months now and an exchange with another make was a no go as this company only deals with JVC head units (maybe why I got it cheaper than elsewhere) - Hopefully this will all be sorted out - I must admit I am a bit dissapointed as it was not a cheap unit being there flagship model
    Anyway guys thanks for the input
    Many thanks
    RON
  7. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
  8. Hawklan
    Hawklan
    Oct 20, 2001
    6,744
    Essex
    +312
    Thanks for the link - But all should be OK
    I'm expecting the head unit back some time next week
    Many thanks
    RON
