JVC HDTV in UK
Discussion in 'General TV Discussions Forum' started by ReTrO, Nov 30, 2003.
  1. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    I'm not sure what people already know about the JVC TV rnage, but as they do the D-Theater HD-DVHS decks they also do a pair of CRT TV's that will accept a 1080i/1125i component input.
    See here:
    36" HV-36P38
    32" HV-32P37
    That and they don't cost much. About £1,500 and £1k respectively and less if you look around.
    :smashin:
  2. jGrahamD
    jGrahamD
    Feb 11, 2002
    263
    I wonder if these display ture HD, or whether the image is re-scaled to standard definition.
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    They display native 1080i and upscale other low-res sources to that resolution also.
  4. CKNA
    CKNA
    Nov 26, 2003
    126
    USA
    +4
    I highly doubt that it upscales SD to 1080i. Nowhere does it say that. It only says that it scales to remove flicker which is basically 100Hz TV.
  5. kev_melon
    kev_melon
    Sep 26, 2002
    55
    9
    I'd rather not say...
    Just found this by looking on the link provided:
    Full Compatibility including 1125i HD Signal Reception
    Global compatibility is another advantage JVC D.I.S.T. has to offer and this means that you can enjoy NTSC system material from a DVD or VCR. Furthermore, these new TVs are capable of receiving high-definition 1125i format signal.
    Does this DEFINITELY mean that they can receive 1080i/1125i signals. Colour me confused!:confused: :rolleyes:
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    The DIST is their upscaling software for the TV's that converts all sources upto 1080i.
    Would there be any point in scaling to normal sources to 1080i and then back to 576i? Not really.
    I'm thinking about asking for a loan model for work, to give a spin with our resident JVC D-Theater SR-VD400E deck.
  7. CKNA
    CKNA
    Nov 26, 2003
    126
    USA
    +4
    The DIST is to make the TV 100Hz with 576i/50Hz signals. This TV is not even progressive scan. It does not scale to 1080i. It clearly says that. All it does is accept 1080i signal on its component input. If it really scaled to 1080i it would cost more than £1,500. There isn't even HDTV's that cheap in US that scale to 1080i.
    Besides, it is not even HDTV that means that it will not resolve most of 1080i resolution anyway. Just because the TV can accept 1080i signal it does not make it High Definition. We had the same situation in US in the beginning. Manufacturers were selling TV sets as HD even though the only thing they had common with real HDTV was that it accepted 1080i signal. If you want real HD, get HD Plasma. I believe you can get one from Panasonic in UK.
  8. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Taken from JVC's website.
    http://www.jvc.co.uk/article.php?id=100209
    Following JVC’s Progressive World strategy JVC are continuing their commitment to the Progressive future with all three TVs offering Progressive Scan-ready component inputs. Connection to a Progressive PAL source such as JVC’s XV-NA77 DVD player or DR-M1 DVD recorder will deliver outstanding picture results.
    Have you read about DIST?
    There's plenty on the page I've linked to.
    It's runs at a refresh of 75hz rather than 50 or 100hz and at 33Khz over 15Khz horizontal refresh.
  9. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Having written that I think the PAL sources are actually done to 1250i/1152i @ 75Hz. So 1080i is within that spec.
  10. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Richard, what's the form on the D-VHS decks? Are they available yet?
  11. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
