jvc hd750 lens shift
Discussion in 'Projectors, Screens & Video Processors' started by tommy83, Feb 21, 2013.
  1. tommy83
    tommy83
    Jul 13, 2008
    140
    staines
    +4
    can a jvc hd750 project onto a 2:35:1 screen without an anamorphic lens??
  2. Dan L
    Dan L
    Feb 7, 2005
    2,204
    Wotton-under-Edge
    +110
    Why don't you just start one thread and list all the projectors you'd like to know which can project an anamorphic image without a special lens. Just a thought.
  3. tommy83
    tommy83
    Jul 13, 2008
    140
    staines
    +4
    you dont have the answer then!
  4. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,062
    +7,991
    Yes:provided the projector is within the zoom range for the size of screen you want to use. You have to use the figures for a 16:9 screen of the same width to see if it will work in your particular room.However, if it won't work with a HD750 (or any of the newer JVCs) then it probably won't work with any other projector since they are amongst the most flexible in this regard.
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,916
    UK.
    +3,397
    A zoom ratio greater than 1.33 ensures that a projector can do both 16:9 and 2.35:1 at the same height, so look for one that has that range and make sure you place it in a position so the zoom facilitates CIH.
    Gary
