JVC GRDVL767 or 367
B
buzz56
I like camcorder that allows video in/out and also like transfer family home videos from VHS tapes to digital format (SVCD and digital cam formats).
I've been deciding between JVC GRDVL767(£519) and 367(£449):
( these prices from www.askdirect.co.uk)
1) what's the difference? is it worth the extra £100
2) some advertisers selling as 767EK , what does EK bit mean?
I shall be grateful for advice on these or similar priced camcorder
Thanks a lot
gringottsdirect
EK suffix is simply full JVC model number.
GR-DVL367EK vs GR-DVL767EK
No Lens Hood vs Lens Hood
8mb MM Card vs 8mb SD Card
800k Pixel CCD 520 Lines Res vs 1.02 Megapixel 530 Lines Res
Max 1024x768 vs Max 1280x960 HG Digital Stills
556g vs 567g Weight
Whether it's worth £100 for higher resolution only you can decide...
B
buzz56
Thanks for prompt reply
I will order the 767 model on monday
In the mean time,can some one suggest a model with similar specs for about £520
CHEERS
General note:
For the last few months i've been researching about the camcorder to buy by looking thro' magazines and adverts.
Then today , i found this forum web page. it's great!!
I've been looking around it for some hours
WELL DONE you nice people out there
this is what the internet was really meant for
