jvc grd93 passthrough??
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by disastermaster, Jun 19, 2004.
  1. disastermaster
    disastermaster
    Dec 10, 2002
    48
    I'm thinking of purchasing a Jvc GR-D93 camcorder and I've read conflicting specifications, could anyone confirm these couple of points.
    1 does it have analogue to digital conversion with pass through?
    2 can you record movie to the memory card or just stills?
    3 Wheres the best place to buy from in the UK!!!
    TIA disastermaster.
  2. mjw123
    mjw123
    Apr 21, 2004
    1,302
    48
    +32
    Yes - but youi need an extra adapter - this wasn't clear and caused me a lot of headaches trying to get it to work without it
    Not sure - haven't tried. You can move frames from the tape to the SD card as stills but not sure about recording ot card...why would you want to do this ?
    Try pricerunner.co.uk or dealtime.co.uk - I got it for £395 but I'm sure it'll be nearer £375 now. Nice bit of kit by the way !
    Mike.
  3. disastermaster
    disastermaster
    Dec 10, 2002
    48
    Thanks for the reply. What is the adapter that you need to use the pass through? Whats it like filming indoors with the cam in lowish light? Also how long does the battery last? Any good or bad points would be appreciated.!
    Thanks Disastermaster.
