JVC GRD 53 vs JVC GRD 70
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Stuteman, Jun 3, 2004.
  1. Stuteman
    Stuteman
    Dec 10, 2003
    73
    I am buying my first Camcorder and like the look of the JVC 53 and 70. Not much difference between them in price (£315 and £300) but has anyone had any experience of them.
    Any other suggestions at around same price?
  2. Mentorron
    Mentorron
    Jul 1, 2004
    14
    The 2004 JVC's have much better video quality than the 2003 units. The old units usually ended in a zero: the new ones in a 3. The main feature to watch for and get is 3D Noise Reduction. It gives better low light noise performance and brightness, and better color saturation in stronger light.
