jvc gr-fx11 camcorder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by nightjar, Sep 28, 2005.
  1. nightjar
    nightjar
    is my camcorder ok to edit my videos using a pc. what cables would i require
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,336
    Rainham Essex
    +2,433
    Yes it can be done, but not easily as the camcorder is analogue (VHS-C) :(
    To be able to get the video onto the PC you will need an analogue to digital capture device such as the Canopus ADVC converters that will connect to the PC via a firewire port. These cost around £150+ depending on the model. Have a look at These.
    A cheaper option is a USB2.0 capture device, but the results from these tend to be fairly poor with lower quality video & often the audio out of sync. But they do cost a lot less at around £30. Have a look at This for an example.
    Mark.
