JVC GR-DX95 Driver for Windows XP
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by crawlerm, Jul 12, 2004.
  1. crawlerm
    crawlerm
    Jul 12, 2004
    4
    I did have my camcorder working with my PC but have changed PC and mislaid the CD that came with the camera. I did think that Windows was supposed to automatically install the driver but it doesn't. I suppose I could try to get hold of another CD from Jessops but this doesn't seem very promising considering the service I've had in the past. I've searched all the driver sites I know as well as JVC. Can anyone help?
    Bob
    :lease:
  2. Brian110507
    Brian110507
    You don't need a driver for Windows XP if you are capturing by firewire. Do I guess you are using USB or some other capture device, if so then it is a software programme your looking for not a driver.
  3. Taff_o
    Taff_o
    Did you have any joy with this as I have the same problem, or do I just need to get a firewire card?
  4. crawlerm
    crawlerm
    Jul 12, 2004
    4
    Hi - yes I solved this ages ago. The answer is to use firewire. The USB connection, which works with the software supplied, gave a very poor quality picture anyway. With firewire you don't need any driver for the camera, a cable will cost about £15 though.
    Bob
  5. ovidiuuk
    ovidiuuk
    Sep 2, 2008
    Hi Crawlerm,
    please tell me if you know if I can use and how, my mini dv jvc gr-dx95ek on Macbook pro. I tried yesterday to connect and didn't work. How is working firewire and where shell I find the cable? How I will connect between video camera and laptop? If you can't help me can anyone help?Thank you!
