Jvc GR-DVP5 Help on vista
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Av_Dave, Jan 13, 2008.
  1. Av_Dave
    Av_Dave
    Dec 28, 2003
    30
    Birmingham
    Hi all, i am trying to connect my camcorder to my laptop its running vista, i have tried installing the usb drivers then connecting the cam but its says drivers not installed correctly, all i want to do is capture the video on the tape and transfer it to my laptop, is this the best way or will it be easyer via dv or do i need drivers for this aswell?
    many thanks
  2. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
    I tried to do this with my sony camcorder via usb and it wouldnt work turned out that my one would only work with the small firewire lead or as sony call it ilink. Picked up a lead from my local computer store for £6 and I dont know why sony gave a usb lead with the camcorder and no firewire/ilink. Oh and make sure your laptop and camcorder have the right connections for firewire.
  3. Av_Dave
    Av_Dave
    Dec 28, 2003
    30
    Birmingham
    Thats great thanks, do i need software when i do it via dv?
  4. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
    I used the software cd that I got with the camcorder but you can just use windows movie maker thats built into vista to add the video to the computer then edit them.
