JVC GR-D23, GR-DVL167, or Panasonic NV-GS11?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by ravve, Jun 25, 2004.
  1. ravve
    ravve
    If all the four cameras above cost approx. equal, wich one woud you have bought? I´m considering the JVC GR-D23, since the GS11 is little more expensive, and the DVL167 is from year 2002 (so i´m unsure if it is good since it is such old)... what do you think?
    Or maybee someone have any other suggestion to a DV camera in the same price which are better than these?
    PS this is my first thread here, so be nice and answer =)
  2. Mentorron
    Mentorron
    Jul 1, 2004
    14
    If the 23 has the new 3DNR feature, it does great in low light. Make sure it has the features you want, especially input/output ports, such as DV in/out, S-VHS, AV in/out. Many low end units remove the input capability of the ports, and leave only the outputs. You have to check the menus to ensure they can be switched from output to input capability.
  3. andy1234
    andy1234
