stevieg662
Hi I have a JVC LT-24C680 and have just set up my sky glass puck with the sky glass remote paired with the tv - however although the sky remote turns the tv off - within 20 seconds a floating red square showing "no signal" and 3 minute countdown clock appear then after 3 mins the TV goes off but then I cannot turn it back on with the sky remote although it is supposedly paired - however if i then turn tv off using jvc remote then I can turn back on with sky remote. So I do not want to have to use 2 remotes - sounds bit long winded but hopefully someone can fathom it out for me.
