JVC FR1 - Sony DAV-S500: S Video in Black and White - why???
Discussion in 'General TV Discussions Forum' started by scartman, Mar 27, 2002.
  1. scartman
    scartman
    Mar 19, 2002
    10
    As the subject suggests, i'm trying to rig up my new JVC 28FR1 to my Sony DAV-S500 via the medium of S-Video.
    I've tried plugging a lead straight into the front S-Video socket on the TV and also through a SCART adapter.
    Unfortunately, both ways produce a black and white picture. :confused:
    What am i doing wrong? And what can you recommend to try?
    Dave
  2. wakelings
    wakelings
    I had the same problem with my DAVS800. You need to plug the SCART cable into a different AV port on the TV. Try AV2. There is a techincal reason as to why you cannot use AV1, I think this is detailed somewhere on this forum, but I cant remember!
  3. scartman
    scartman
    Mar 19, 2002
    10
    Cheers, i'll have a try when i finish work...
  4. Guest
    scartman,
    Wey hey, another DAV S500 owner!! We are growing!! AV2 will definately work.
  5. Rock Da Bass
    Rock Da Bass
    Jan 27, 2002
    5,785
    EU
    +816
    Scartman,
    I've got a DAV-S500 with JVC telly and had exactly the same problem.
    The solution (from a reply on this board) is to plug the scart into EXT 2 (or 3). Then you must go to the EXT settings on the TV setup menu and change that EXT to an S-Video input. Done by pressing the yellow fastext button or something (you'll find it easily enough). Without changing that, you'll just get a B/W picture.
    RDB :)
    I'll have a look at the exact way of doing it tonight, just in case I haven't explained it well enough just now.
  6. scartman
    scartman
    Mar 19, 2002
    10
    Thanks everyone for the advice. TV is now in outstanding S-Video colour!
    Dave
