JVC Flashing Green Light
E
elliotrobinson
Evening,
my JVC 32" power light has started flashing(green). When turned off it flashed red.
I have to be honest and I have unplugged the TV and everything ok, anyone any idea what this was though? Anything that could cause a future problem?
Thanks in advance
Elliot
Russellgti
A bit of a conicedence but my JVC LT40DS7 has started doing this as of last saturday. It is 10 months old BTW. It is supposed to mean that a program that you marked in the DTV planner is about to start, but I have never used this option.
One potential solution is when you have DTV on the screen go into the menu and then the sub menu for DTV and one of the choices is Rec Timer, see if you have any entries and if you have the option delete all the entries.
Mine are all set to inactive and on my model I don't have the option to delete them.
