JVC failure after 1yr and 4 days! Keep it or bin it?
Discussion in 'General TV Discussions Forum' started by Brian_the_cat, Jan 9, 2005.
  1. Brian_the_cat
    Brian_the_cat
    Hi all
    I would very much welcome some advice. I have a JVC 28GT1SJF that has gone badly wrong 1 year and 4 days after I bought it. :mad:
    When it is switched on there is not picture. The screen is an even grey with bright horizontal (well almost) lines about 3 inches apart. This brightens over a period of about 3-5 seconds and thene the set gones into satndby on its own. There is sound.
    I bought it at Comet - they will charge 50 quid plus parts. Since the TV cost 299 I'm not convinced that its worth getting it looked at since I have no idea how much the parts would cost for such fault.
    Should I get them to try to fix it or go get another set? :confused:
    :lesson: Next time I'm going back to John Lewis. My Toshiba 32WD98B had a problem in November last year, 59 months after I bought it. They fixed it no quibble and that was after porice matching down from 1600 to 1200 nearly 5 years ago. My recommendation - always go to John Lewis for TVs.
    Thanks for any advice.
    Keith
  2. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    Check this out:
    http://www.dti.gov.uk/ccp/topics1/facts/salegoodsact.htm
    It is reasonable to expect a TV to last more than 1 year and 4 days.
    If you bring it to JVC's attention, they may offer to repair it anyway (for free), but you may have a fight on your hands - it all depends on how much effort you want to put into getting it sorted out.
  3. GaryB
    GaryB
    Nov 12, 2002
    5,386
    St Albans
    +1,292
    If it's only 4 days outside guarantee, JVC will cover it. Give them a call - 0870-330-5000. If you have any problems, PM me and I'll get it sorted.
  4. nig28
    nig28
    You could also look in the yellow pages for a alternative repair company, you can take it to any authorized repair agent.
    Nigel
  5. Brian_the_cat
    Brian_the_cat
    Was on the way to the CAB to check out GreenBars suggestion. Before leaving I checked back here and found GaryB's post. Called JVC and they are happy to authorise a local repairer to fix the problem. They want me to send them a copy of the invoice and a cover letter which I'll do in the morning.
    Thanks for the info to all - very useful indeed. I'll update this thread later when the repair is all done. Here's hoping!
    :thumbsup:
    Keith
  6. red16v
    red16v
    Aug 20, 2004
    552
    +5
    I'm always pleased to read postings about major manufacturers doing the 'decent thing' - and JVC are by no means alone in this. Sort of 'restores my faith in mankind' ! Regards, yt.
  7. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    I'll second that. :thumbsup:
    There are so many poor deals out there, that when there's good service, we should shout it from the roof tops. :clap:
  8. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,608
    2
    In a secret location with Jennifer Lawrence
    +9,316
    Don't get it repaired yourself. Definitely follow the advice above. A lot of companies try and fool consumers into thinking that after the 12 month guarantee they are screwed if an item goes wrong. But as mentioned above that is all a load of crap. Anything you buy is expected to be of merchantable quality and should last an expected amount of time.
  9. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    Glad to be of help Brian.
  10. GaryB
    GaryB
    Nov 12, 2002
    5,386
    St Albans
    +1,292
    Some general advice for anyone else who has problems like this. You'll find you get a much better response from any manufacturer if you ring and explain the situation rather than going straight for the CAB/Legal Action route. Like you or I, they don't respond well to threats. The staff who work for most of the better manufacturers (I'm one, in case you hadn't realised) are reasonable people and know that retaining an existing customer is a lot easier then gaining a new one. They also appreciate that if they refuse to help on a TV such as this that's just out of warranty, the customer will do two things:
    1. Never buy that brand again.
    2. Tell everyone they know of their experience.
    Neither of which are good for business.
  11. Brian_the_cat
    Brian_the_cat
    :clap: :thumbsup: :clap: Today JVC delivered a new TV to replace the broken one. They would have had it repaired but couldn't find a repair agent within a reasonable distance so offered to replace the set foc!
    A great result and a satisfied customer.
    :lesson: GaryB was right - always try the manufacturer in the first instance.
