JVC DX7 LP Problems
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mrmc74, Jul 8, 2002.
  1. mrmc74
    mrmc74
    Nov 28, 2001
    122
    Netherlands
    I've recently recorded on LP mode and there are problems with the picture. Sound is fine but there are horizontal pixellated bands 1/4, 1/2, and 3/4 down the picture.
    Haven't had any problems in the past and there's no problem on SP.
    Is there anything that can be done to salvage the footage???
    Does it need to be serviced? It's had minimal use in 2 years...
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,915
    71
    50 Rue St Georges, Paris.
    +32
    Have you tried a head cleaner and some new tapes?
    Your footage may be better once problem solved, otherwise no.
    Sounds like an inspection/or service is required, despite minimal use. Your camera has been under-used, common problem.
    Also try winding tapes through back and forth a few times, and using FF and Rewind Visual Search, might clear things up.
    Be aware that repairs and servicing to these is very specialised, hence pricey, typical charge £100 plus VAT.
