D
daft
hi all
Just thought I'd ask for you advice on something technical - it's TV\DVD related.
We've had a widescreen JVC tv for about 2 years, never had one problem with it.
Bought the DVD home cinema system at Xmas, plugged it in (with only subwoofer & one speaker connected - left the other 4 speakers until we got stands - manual said this was ok anyway) - all worked perfectly.
THEN plugged in the other 4 speakers when we got the stands last week. This is when it all went pear-shaped.
When the DVD is on, none of the remote controls work. The sound only comes through 2 speakers, and I can't change any of the settings because you need the remote control to do that.
(the remote control has brand new batteries in it as that was the first thing I thought of)
Once the DVD is switched off and the TV switched on & off at the mains, the TV control works again sometimes. Have tried pulling all the scart leads out, unplugging all the speakers, plugging the scart leads back in and leaving the speakers out, plugging everything back in, none of it seems to make any difference.
Even when I put the playstation on to de-stress after all the messing about, the tv control worked then stopped after a few minutes, then started again after "rebooting" the tv. And the TV control has new batteries too!
Dunno what to do. All these problems have started since I plugged in the other 4 speakers...
The worst thing is that I know connecting speakers should really have no effect on remote controls etc. ALL controls lock up once the dvd is switched on, including the TV remote, digital (satellite) remote, and the dvd remote itself.
Total tech-hell!!!!
thanks in advance
Dave
spec:
dvd system: THA 35
(XV-THA35 dvd player)
(SP-THA 35 speakers)
TV: AV28 TV
Total tech-hell!!!!
thanks in advance
Dave
spec:
dvd system: THA 35
TV: AV28 TV
