JVC DRMX1 - Any Views Folks
Discussion in 'Blu-ray & DVD Players & Recorders' started by LizzyF, Mar 31, 2005.
  1. LizzyF
    LizzyF
    Feb 21, 2005
    77
    I keep looking at the JVC DRMX1.
    The appeal is that it is a 160gb Hard Drive Recorder / DVD Recorder and VCR all in 1 unit. I can't find any views or reviews on this model
    I had the JVC Model, DR-MV1 but it became faulty and I had to send it back. I was very impressed with it unil it broke.
    Regards
    LizzyF
  2. jayboro
    jayboro
    Hi Lizzy
    I was looking at the same model especially as it has HDD, DVD, Video and I-link for DV camcorders. I was minutes from buying it when I read that it does not have RGB Scart input, which is a prerequsite for recording from Sky/Sky + and Freeview.
    I need to do some more research but if this is the case it makes it useless for me.
    Alas I have not found anything similar that offers a true all-in-one at a reasonable price.
    Hope that helps.
    Jay x
  3. jayboro
    jayboro
    The more i read in to this the more confused i get. If anyone can shed light on whether this JVC has RGB input and can it be used to record sky please let me and lizzy know.
    Some sites say it does and others say it doesn't.
    Perhaps I'm not that much use to you Lizzy afterall.
  4. Bev478
    Bev478
    Apr 13, 2005
    140
    +8
    I was also looking at this machine & it definitely does not have RGB input. Panasonic have just brought out a 3 in 1 machine which has it (I think?), but only analogue tuner. If it had a digital tuner I would have bought it.
