Quantcast
JVC DRMH30 on Unbeatable
nunew33
Prog scan, large HDD, componant, DVD RAM RW and R
Not sure of RGB in but everythingesle is there for £520
Im looking for someone to warn me off. If thety dont, my order will be in tomorrow
nunew33
Guessing no RGB in because DMRH10 doesnt have it.
Is anything else this cheap with these features?
nunew33
What? No reviews, opinions or discouragement.
Damn, Ill have to place an order!!!
Before I do a few questions.
Can I assume its a DMR 10 with a hard disk so function/socketry wise its the same. I can find DMR10 literature but nothing more than a french spec sheet for the 30
R
rwgdegraaf
I am also very curious on this one. I want to buy this one also in Holland. The only thing i got is:
These are the technical specifications:
• Playing: HDD, DVD-Video, DVD-RAM, DVD-RW, DVD-R, CD, SVCD, VCD, CD-R/RW, WMA/MP3/JPEG digitale foto's (CD-R/RW)
• Recording: HDD, DVD-RAM, DVD-RW (VR en Video), DVD-R
• Hard Disk Recorder with 160 GB :
• XP stand (10 Mbps) voor 34 hour
• SP stand (5 Mbps) voor 68 hour
• LP stand (2,5 Mbps) voor 136 hour
• EP stand (1,6 Mbps) voor 204 hour
• FR stand (10-1,2 Mbps) voor 34 - 272 uur (instelbaar in 63 stappen)
• NICAM/A2 stereo decoder
Pictures with high quality
• PAL Progressive compatibility
• Intelligent Dual-Pass Encode Dubbing (HDD-->DVD)
• Motion Active Progressive Scan (videosource)
• Digital Direct Progressive Scan (moviesource)
• Super MPEG Encode Pre-Processor: Time Base Corrector, Frame Synchroniser en Motion Active Noise Reduction
• Super MPEG Post-Processor: Block Noise Reduction, Colour DigiPure en Hadamard Noise Reduction system
• i.LINK aansluiting (DV ingang) (HDD)
Playing /recording
• 8 hour recording on DVD
• Live Memory (HDD) & Live Memory copy (HDD->DVD)
• Recording and Playing at the same time (HDD)
• RetroActive recording (HDD)
• Relief Recording (HDD)
• Splitting recordings (HDD)
• Linear PCM audio recording (only in XP stand)
Editing/Dubbing
• Dubbing on high speed, max. 32x (HDD-->DVD)
• Only Dubbing (HDD-->DVD)
• Playlist editting
• Easy copy
Ease of use
• Library Database DVD Navigation
• HDD/DVD Navigation with moving thumbnail (DVD-RAM/DVD-RW VR)
• Index Picture Navigation
• Help function and GUI (Graphical User Interface) with high resolution (10 languages)
• DVD-R menu with "thumnails" (18 indelingen)
• Finalisation clear (DVD-RW)
• Timerecording (ShowView Deluxe, Rec Link (HDD), On-Calendar Programming)
Audio
• 192 kHz/24-bits audio D/A converter
• Dolby Digital/DTS/MPEG Digital uitgang
• Virtual Surround
Video
• 10-bits/54 MHz video D/A converter
• NTSC weergave op PAL TV (DVD)
• Automatic recording en playing in 16:9
• Instant Replay, Quick Skip, Time Skip, Live Slow
• Search with variable speed
• Natural Reverse Playing (-1x)
• 30-disc RESUME functie
• Time: 1 jaar, 16 programs
• T-V Link
• Auto PDC/VPS
• Plug & Play
• 99-channel Frequency Synthesised B/G, D/K Tuner met Hyperband
• Power Save Mode
• Permanent program memory
• 60 minutes power backup
• Remotecontrol voor different brands TV/DVD/satellite receiver
• Two SCART connectors, decoder/PDC/VPS
• AV input on front
• Video output: Component en S-Video
• Analogue audio output: voor L/R
• Digital audio output: optical en coaxial
Please help us otherwise I am going to order this one too!
nunew33
nunew33
Looks like the JVC does RW in video and VR modes. But im guessing thats no big deal for what I want.
If that RDX32 hadnt shown up I would have a DMRH30 on order by now!
Similar threads
