JVC DRM-10 or Pannasonic DMR-E55
Discussion in 'Blu-ray & DVD Players & Recorders' started by nigelw2004, Oct 29, 2004.
  1. nigelw2004
    nigelw2004
    Can someone advise which of the above is best. I need something easy to use with timeslip, 8hr rec time, jpeg, and good quality/reliability. Oh and I understand some DVD recorders have fans which run all the time, are these noisy? Are there any known problems with either product other than the menu thing on the Panasonic mentioned in the forum?
    For info I already have a JVC TV (1 yr old). Thanks.
    Nigel.
  2. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    I have the E55. I find it simple to use.Also absolutely silent. I don't think it has a fan, but I may be wrong.PQ is ggod too. 10/10 for me.
  3. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    I've got the e55 in my bedroom and the fan produces a bearly audible -occasional- hum. It shuts off when the machine is put into standby. :thumbsup:
    It's less noisy than my vcr's motor noise.
  4. Benfica
    Benfica
    I think that E55 doesn't play CDs with jpeg files. Can somenone that has a E55 confirm this ?
    (This was a requirement of nigelw2004)
    Best regards
