JVC DR-MX1 Programme Titles
Discussion in 'Blu-ray & DVD Players & Recorders' started by johnhoward111, Jun 19, 2005.
  1. johnhoward111
    johnhoward111
    Does anyone know whether the JVC DR-MX1 should capture programme titles when programmes are being recorded to the HDD? The instruction manual doesn't mention them anywhere. Any help would be very much appreciated.
  2. GaryB
    GaryB
    Nov 12, 2002
    5,381
    St Albans
    +1,292
    No it won't. It only has an analogue tuner and the only way to do that in analogue would be to include a teletext decoder and extract the titles from that.
    The forthcoming DR-M150 DVD recorder with integral DTT tuner can do it.
  3. johnhoward111
    johnhoward111
    Gary
    Thanks very much for your quick reply.
  4. LizzyF
    LizzyF
    Feb 21, 2005
    77
    Hi John,
    nothing really to do with your question but I have a fancy for the JVC model. I keep looking at the forums and have asked for views on this model but have had no replies. How long have you had the MX1 and what are your thoughts on it.
    Regards
    Lizzy
  5. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    I never could find any mention of it in the Panasonic manuals but was pleasantly surprised when I found it did auto-naming. As far as I know, the Panasonics are the only models that do this apart from non DVD machines such as the Topfield 5800.
    I am quite pleased with the MX1 although the machine sometimes does not like going backwards in the 3 hour buffer and converting the buffer to a permanent recording. I have also yet to find any DVD-R that will work at greater than 1x speed for dubbing. The manual states that I should "JVC" DVDs but have yet to find any. I have tried various brands from 2x 4x 8x and 16x - they all work but only at single speed despite setting the high speed option. DVD-RAM HD>DVD copies work at 2x though with all discs I have tried. I bought mine from Comet who did a price match and gave me £150 off their price and an extra 10% - turned out to be a very good deal!
