Jvc Dr-mh30sek
Discussion in 'Blu-ray & DVD Players & Recorders' started by vidaesunlibro, May 4, 2007.
  1. vidaesunlibro
    vidaesunlibro
    i have a JVC dr-mh30sek and when i plug it in i get no picture, the DVD and HDD buttons light briefly then switch off and it says loading and the drive flashses blue.
    when the DVD player is saying loading none of the buttons work. i pressed the eject button on the drive itself and it still doesn't open which makes me think it might be a power supply problem but i can hear the HDD spinning.
    There were 2 capacitors leaking that i replaced and that solved nothing. does anyone have any experience of these dvd hdd recorders? does anyone have a problem like this and fixed it?
    thanks in advance.
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
