JVC DR-MH30 RGB input
Discussion in 'Blu-ray & DVD Players & Recorders' started by denson, Nov 14, 2004.
  1. denson
    denson
    I am thinking of ordering this DVD recorder and am fully aware that it doesn't support RGB input on the SCART socket. It does however support RGB input on SVIDEO. I am thinking of buying an SVIDEO to SCART converter to run SCART from the sky digibox (AMSTRAD DRX-400) to SVIDEO in on the JVC recorder. Am I right in assuming that this will give me my RGB input for recording?
    The other question is that will the VCR control be available when using the SVIDEO input? What I mean by this is whether the sky box will be able to turn on the JVC recorder and get it to record programs if and when I have programmed my Sky personal planner?
  2. Dan M
    Dan M
    May 28, 2004
    34
    Problem is, the s-video on the jvc is on the front panel. This can look very messy.Also i had no end of trouble with my DR-MH30, to the extent that i changed it for a Panny E95. I'm sure i read that JVC had recalled this model because of problems.
