JVC DR-MH20S and SKY+
Discussion in 'Blu-ray & DVD Players & Recorders' started by salfordred, Feb 28, 2005.
  1. salfordred
    salfordred
    Feb 2, 2005
    89
    I am considering buying the JVC DR-MH20S as my first DVD recorder, as it seems to do everything I need. I know Sky+ has a HDD, but as it never seems big enough, I want the oportunity to transfer some of my recordings to the DVD hard drive, and possibly then put them onto disk. I feel that with having a Sky+ HDD and a DVD HDD.... along with the possibilty to record on a number of formats, it gives me a whole lot of options.
    Now for the question...... How easy does this DVD player connect to SKY+ ? There must be people out there with this set-up.
    Any advice, or other player options will be very happily received.
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    As JVC do not have an RGB input you would be better off choosing another brand.However,if you want to stick with JVC you can use the s-video output on the back of the Sky+ for near RGB results
  3. Rasczak
    Rasczak
    Apr 3, 2002
    23,169
    Warwick
    +3,779
    Very easily. The S-Video output and left/right audio outputs can be fed to the MH20. However if Sky recording is your prime motivation in getting a DVD recorder then, as Phelings suggests, a model with RGB input such as a Panasonic E85/E95, Toshiba RDXS32 or Pioneer 420/520 might be more suitable to your needs.
    For general DVD recorder buying advice take a look at the 'Which DVD Recorder?' link in my signature!
  4. salfordred
    salfordred
    Feb 2, 2005
    89
    Any suggestions on something in that price range that will do the following ?
    Write to
    DVD-R
    DVD-RW
    DVD-RAM
    i-link
    DV input
    Playback
    DVD-RAM, DVD-RW, DVD-R, SVCD, VCD, CD, CD-R, CD-RW, MP3/JPEG, on CD-R/RW
    ..... and also have a decent playback
    ..... Oh.... and multi-region
  5. Rasczak
    Rasczak
    Apr 3, 2002
    23,169
    Warwick
    +3,779
    The Toshiba RDXS32 is the best match - a very popular machine on the forum for very good reasons. Have a look at the specs here. Do note though that iLink and DV input are one and the same - if you are referring to a Digital Video input such as DVI or HDMI then it will be years before any recorder has such an input. And the Toshiba doesn't support SVCD discs.
    NB: Link is for reference - you may (or may not) be able to get it cheaper than that!
  6. salfordred
    salfordred
    Feb 2, 2005
    89
    That's spot on mate..... thank you Rasczak (and also thanks to Phelings)
