JVC DR MH20 with Sky+?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Zaria, Jan 9, 2005.
  1. Zaria
    Zaria
    Does anyone have this recorder set up with a Sky+ box? If so how is it connected, 'cos my setup doesn't seem to be working.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,220
    Argyll
    +2,267
    How are you currently connected? The JVC does not have RGB Scart input and so your best bet is to use the S-Video out and left/right audio jacks on your Sky+ box to the Scart input on the JVC. Ensure that S-Video is set in the DVD recorder's menu and the relevant input channel is set.
    To help further we need more details:
    - What TV/screen are you using?
    - Are you getting a picture from the DVD recorder on the screen?
    - How is your DVD recorder connected to the screen?
    - Are you using decent quality cables?
    - How is your setup not working? Do you have sound and no picture? Interfence? Nothing at all?
    Help us to help you!
