JVC DR-MH20 - is it really that bad?
Discussion in 'Blu-ray & DVD Players & Recorders' started by gazza30, Sep 18, 2004.
  1. gazza30
    gazza30
    Have seen a couple of negative reviews on this machine. Is it really that bad, anyone got anything good to say about it?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,785
    The JVC models seem to have got a bit of a bad press at present: they have had a few problems (which JVC have been working to resolve) and are up against some formiddable competition at present (current Panasonic/Toshiba offerings are very strong) and thus JVC is yet to make it's mark. The lack of RGB input is very disappointing. Potentially they do look good models - and I'm sure once the bugs are ironed out they will be strong contenders.
  3. Kasparaitis
    Kasparaitis
    im seriously thinking of getting one.
    due to the fact it doesn't have RGB will recordings off sky be about the same quality as tape?
  4. 888
    888
    I have the MR1. The lack of RGB is certainly sad. But to be honest I have not noticed any difference between the recording I've made using s-video and viewing the RGB directly out from the decoder into the RGB input of my PA20. If anything I find the MR1 cleans up the picture sightly.
    People seem to hung up about RGB input. Often the source from the sat decoder is poor anyway and that is more likely to be your weakest link
    Also, alot of decoders do not have 2 RGB outputs so you'll have to choose between viewing with RGB or recording with RGB.
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,785
    You'll also find dozens and dozens of posts in this forum from people who have upgraded their TV/screen and suddenly realised that RGB is actually noticeably superior to S-Video from Sky/Freeview digiboxes!
  6. ACoolDude
    ACoolDude
    Sep 9, 2004
    12
    I have a DRMH30 which has just been replaced (well it has a different serial number) by the supplier because of firmware bugs in my original machine. I have only had it one day so far so its not clear whether anything has been fixed but the first thing it did was trash a DVD that i had forgotten to finalise with my first machine so not the best start!
