JVC DR-M10 & Media
Discussion in 'Blu-ray & DVD Players & Recorders' started by spannerman, Aug 6, 2004.
  1. spannerman
    spannerman
    Jul 21, 2004
    16
    LUTON, Beds. UK
    I've just purchased a JVC DR-M10 DVD recorder, and would like to know forum members preferences as to which blank media to use. What are your recommendations to use in the said machine, apart from JVC's own.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,281
    For DVD-RAM I suggest using Panasonic or Maxell brands - the non-caddied versions as these have a special coating to make them more durable and you won't have to take them in and out of the cases. Try the Panasonic E-Shop for good prices on these:
    http://eshop.panasonic.co.uk/default.aspx
    For DVD-RW media and DVD-R I suggest always using good branded media. Others on here disagree with that (which is fair enough) but brands such as Pioneer, JVC, Sony, Panasonic, TDK, Verbatim and Maxell offer reliability, compatibility and durability IMHO. Some good online stores are:
    http://www.dvd-and-media.com/
    http://www.blankdiscshop.co.uk/
    http://www.ketta.com/catalog/default.php?cPath=21&osCsid=4164682634847080a07b9f9e95a32dbc
    http://www.cd-rmedia.co.uk/cgi-bin2/cdrmedia/sections.pl?id=12&tab=0
  3. markie
    markie
    Jul 30, 2004
    219
    +11
    Maxell DVD-Ram and TDK DVD-RW work fine in my JVC.
  4. spannerman
    spannerman
    Jul 21, 2004
    16
    LUTON, Beds. UK
    Thanks all, I've just bought some JVC DVD-Ram discs ( 5X @ £19.99 ) and
    TDK DVD-RW ( 5X @ £12.99 ) to try, I'll see how I get on with these.
    Cheers.
