JVC DR-DVP7 or Sony IP7/PC101 and Stills
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by TimK, Jul 30, 2002.
  1. TimK
    TimK
    I'm trying to decide on which camcorder to buy. My requirement is that it needs to be small and able to take good quality stills.
    I have considered to models above but read conflicting reports as to the quality of the stills.
    Any suggestions or any other models which I should consider?
    Tim
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,915
    71
    50 Rue St Georges, Paris.
    +32
    Both the models you mention are excellent movie cameras, with average stills quality.
    Only my opinion but I would buy a cheaper movie camera such as the Panasonic NV-GS5B/NV-GX7B and buy a dedicated 3.0 MegaPixel or better, digital camera for stills.
    If possible for stills carry on with 35mm, thats even better PQ of course.
  3. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    I went for the JVC DVP7 and am very pleased with it.
    On the stills side it's not bad - 1.2 mega pixels - it's as good as the cheap digital still cameras. Picture quality isn't bad as long as you don't go bigger than 6X4" - put it next to a 6X4 taken on my Contax T2, however, and there's a world of difference. Fine for snapshots and for taking pictures for publishing on the web.
    If you want better then go for a dedicated 3, 4 or 5 mega pixel digital still camera.
    Better still (if you can wait for the developing) stick with 35mm film. After all you can always get a negative scanner if you want to mess around with shots you have taken on 35mm film on your PC. I've got a Minolta Scan Dual and, at it's max resolution, it produces a 2336X3504 pixels - that's 8 mega pixels! The MKII Scan Dual is even better - 11 mega pixels.
    Matt.
  4. TimK
    TimK
    Cheers Guys.
    Matt - is the JVC DVP5 the same as the 7 except for DV input and silver?
  5. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,915
    71
    +32
    Yes.
  6. TimK
    TimK
    Just read that the battery life is very poor. Can anyone confirm this?
  7. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,915
    71
    +32
    Compared to it's nearest competitors it's no better, no worse.
