BoeingMan
Established Member
Can anyone offer me advice on a problem with a JVC DLA X9 Projector? The projector suddenly started displaying warning lights on the front panel (3 of) when switched on, after being unused for several months, but was previously working impeccably.I should say that it had been sitting on Standby power all of the time whilst unused.Although I have replaced the lamp, it hasn't cured the problem as hoped for.The Standby lamp lights up Red when the power is switched on at the plug.It changes to Green when the remote is selected to "ON". After about a minute or so, the Warning light LED comes on as a Steady Red and the Middle LED Amber light for "Lamp" starts flashing (Continuous) and there is no activity or sound detectable from within. The Automatic Lens cover is wide open. I know for certain the last time I used it the cover closed over the lens as normal. Somewhere along the line, unbeknown to me, it has opened. All these issues suggest the lamp has reached its "End of Life", although previously it was nowhere near it. I read a review posted (on Amazon) by another purchaser, who described exactly the same problem as I had, and purchased a new lamp and it resolved his problem.
I would be grateful if anyone out there can suggest what the issue might be and how to rectify it. Thank you.. IP
