Quantcast
JVC DLA X5900/X7900/X9900 owners thread
Thatsnotmynaim
Just got this x5900 :)
Have mounted it, briefly set it up and that’s it so far.
Got a picture from SkyQ, nVidia Shield TV, can get one from Panasonic UB900, but only if I turn the wick down on 4k to 4:2:0, is that normal with previous ones?
siamsquare
I have a 18GBps fibre HDMI cable (10m), works perfectly!
Steve Withers
Reviewer
Are you sending the signal directly from the UB900 to the X5900? If so it's definitely the cable, the JVC's use full-fat 18GBps HDMI inputs, so the UB900 will output the full signal which I suspect your cable can't handle. I've got the X5900 in for review at the moment and have no such issues with a Premium High Speed HDMI cable.
Thatsnotmynaim
No it’s via my Denon x4300 AVR. I have ordered a shorter premium cable from Amazon yesterday which should arrive later today so will test. What I don’t get is that I had an Optoma UHD550x plugged in exactly the same way yesterday and that has worked fine for the last few weeks.
Steve Withers
Reviewer
OK well it won't be the X4300, so it must be the cable. You'll need to make sure that both cables (the one from the player to the AVR and the one from the AVR to the JVC) are Premium High Speed. They won't have been an issue with your Optoma because it can't support 4K 4:4:4 12-bit but the JVC can handle the maximum output of the UB900.
Thatsnotmynaim
Ok thanks, that’s the key bit of info I hadn’t appreciated. Cable is 10m so guessing a premium cable will only go to 5-8m so I’m looking at exapensive fibre hdmi’s then?!? Any recommendations and rough prices?
Steve Withers
Reviewer
You should be able to find a 10m cable, as long as it's High Speed and rated to 18GBps.
Thatsnotmynaim
I’m guessing copper isn’t going to cut it though over 6-8m? I have a brand new Amazon Redmere (Actice cable) at the moment rated high speed 18gb etc. I also have a couple of other 18gb ones I’ll try, but wonder if 10m is just too much for copper and I’ll need a fibre one?
Russ 66
You might eventually find a 10m cable that works (unlikely though at 4:4:4 4K HDR), the Ruipro definitely will.
Speak to dan @themovierooms I am sure he will do you a deal.
Sunshinewelly
Is there a way of testing a hdmi cable. I need a 8.5 run. I currently have a 7.5 high speed which works. Ie I can game at 4k on PC and through Xbox s with HDR. Can I assume that's more than enough test for bandwidth purposes. Was thinking of joining a one meter extension to see if it worked rather than getting a 10m run which would be 1. 5m more than I need. Not sure whether an extention cable would degrade signal more than running the extra 1.5 m
MLCinema
If the output is the problem, would changing the signal output from the panny not be a solution? Or would the image suffer?
Russ 66
You need to be careful with connectors, I had a 90° HDMI adaptor into my projector for neatness. This caused sparklies with 4:4:4 12 Bit HDR signals, as soon as I took it out it was ok.
Rob.Screene
A quick thanks to Ricky of Kalibrate who supplied me an X7900 pre-calibrated with a few custom HDR modes to replace my X3, including taking time to demo abd impart a wealth of JVC calibration advice.
So far, it's up on the ceiling mount and overwhelmingly good!
Thanks Ricky.
jfinnie
This is what I’ve had to do for now. Fibre hdmi hopefully turning up tomorrow. This is picture on 4:2:2.
Out of interest, what source are you using that makes you care about sending 4:4:4 to the display with respect to UHD content?
I thought all UHD BD is 4:2:0 encoding (even HDR). So if you're outputting 4:4:4 signal from a 4:2:0 media source then I was under the impression all you're doing is duplicating chroma info across the pixels in the player to fill up slots - it is a waste of high bandwidth cable, as the display device on seeing the source is 4:2:0 (or more likely, 4:2:2 by the time it gets out of the player) can duplicate the chroma information itself.
panman40
Everywhere I look lately in uk and USA forums it's all about numbers.. Not picture quality :rolleyes:
Thatsnotmynaim
It’s a UB900, it was more a question of why wasn’t it working. Don’t mind leaving the wick turned down if it’s ok to do and not detrimental. It’s just if I leave it on auto it doesn’t work. Think my Panasonic DX902 maybe prefers it at the higher setting, I seem to remember reading, but later firmware on the UB900 has a lot more settings, 10/12 bit preferred etc... Have I just wasted time/money replacing my £20 hdmi cable with one ten times the price?! :)
jfinnie
Sure, I don't have those devices but it sounds like it should work with a short enough or good enough cable. Some devices can work better than others with a given cable, and that might be what you're seeing.
If you're wanting to watch all 4K content without issues you'd be best off having a 4K60 disc to test with, as that will really push your cable.
Thatsnotmynaim
Well the cable can’t be shorter than 10m as the pj is in another room to the lounge and shines back into the lounge through a hole in the back wall. On the UB900 if you press info you can see how the UHD disc is encoded, I think it said 4:2:0 10 bit when I looked before, but will have a play tomorrow.
Thatsnotmynaim
Yes not fussed about the numbers, it’s how it looks but also finding a setting that’s compatible and good for both tv and pj so it’s easy to use either without having to change any settings etc..
Trending threads
Latest News
UK telecoms come together to keep country connected
  • By Andy Bassett
  • Published
Sharp and NEC display venture to push 8K + 5G tech
  • By Andy Bassett
  • Published
Denon and Marantz bring Roon compatibility to products
  • By Andy Bassett
  • Published
Melco launches home demo scheme
  • By Andy Bassett
  • Published
Virgin Media and Openreach: Our networks can handle surge
  • By Andy Bassett
  • Published
