steviedr
(MOD EDIT: Hi. Please use this thread as a continuation from part 1 which can be found here....http://www.avforums.com/forums/proj...70-x90-uk-specs-discussion-owners-thread.html)
Do you guys know if there is an option to reduce side spillover and save it with the lens memory.
I have a 2:35:1 screen, 16:9/2:35:1 are great but 2:40:1 has a slight left/right spill.
I can apply a mask for this but it seems to keep setting for all ratios.
Is this when I would use user 1-5 settings so I actually load the user and then the saved lens memory?
And final question, when checking convergence, I load the AVS disc and it looks good. What am I actually looking for, is it eg. If there is a red line and there is a tiny blur of red beside it, is this what you guys are moving(pixel) so it lines up?
I'm not going to calibrate greyscale for a while to let her break in, but wanted to make sure convergence was ok.
So far I'm loving it, I will need to reduce the sharpness as there is a little grain.
I guess now I have her I should really read this thread from scratch!
Thanks.
Thanks.
