Zenist
I have a wired situation for my JVC DLA X30. It was brought in 2012 and never replaced bulb (still the original bulb). The bulb is at 1400h, about half of its claimed life (3000h).
Recently my DLA X30 projector stopped projecting while I am playing Blu-Ray using my PS3. The symptom is that it will shut lamp down after a few min with Lamp indicator (orange) flashing twice, Warning indicator (Red) flashing once, and Standby indicator (Red) stay on.After a while the Warning indicator stay on, and lamp indicator continue flashing twice.
You can repeat this cycle by shut it down, and turn on again, playing blu-ray for 2 min, lamp shutdown. For this two min of playing, the quality of picture seems normal, no sign of that lamp is dying.
You may suspect it is problem of lamp life. However I can use the same PS3 to play 1080P video game, playing Netlfix or youtube video which is also 1080P. I can use Chromecast to play netflix, google movie for 1080P, There is no problem at all for my projector to work for hours. And the quality of picture seems no difference from before.
Only if I switch to play blu-ray, the lamp will shut down as I described before.
I am thinking, does blu-ray required more power comsuption because of its high quality picture, somehow that triggered a lamp or circuit protector which shut down the lamp? Or it is actually the lamp is dying.
Have any of you ever experienced that?
