JVC connections to my other hardware?
Discussion in 'LCD & LED LCD TVs Forum' started by Nico Rosberg, Nov 9, 2004.
Tags:
  1. Nico Rosberg
    Nico Rosberg
    I'm hoping to get some advise on hooking up my TV to get the best out of it.
    Whilst it would be brash to say money is no object, clearly I have to be onside with the fact some connectors are expensive but that it's worth it for a panel that cost £1500.
    The panel is a JVC LT32D50, the attached thumbnail shows the back of it. There is also a list of connections in the manual which I have downloaded.
    I you have the time/inclination to help me assume I have no connectors as those I do own are just cheap scarts and several years old to boot.
  2. Nico Rosberg
    Nico Rosberg
    This is the connections page from the manual:
  3. Nico Rosberg
    Nico Rosberg
    My DVD player is a Sony D900G (the one that has a built in VHS recorder):
  4. Nico Rosberg
    Nico Rosberg
    The other Box is my sky Digi, which is about 5 years old and made by panasonic.
    I don't have the manual anymore, I do remember it has 2 scart sockets....
    So, can anyone help?
    Cheers - NICO
  5. machinehead
    machinehead
    Sep 5, 2004
    466
    Greenock
    +12
    are you pleased with
    the picture from this screen?what is it like in analoge.are you in the uk.you are always better to go for quality connections.
