JVC Cam Woes
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by hannay, Jul 15, 2002.
  1. hannay
    hannay
    Jul 4, 2002
    93
    Isle of Man
    I have a JVC GR-DVX2 and a GV-DS2 Docking station. I have connected the docking station to my COM port and installed the software.
    I have two versions of the software: JLIP Video Capture 1.0 and 3.1 - I can get niether to work :mad:
    Are there any other good software programs that will work with this set-up?
    I am desperate for this to work :(
  2. Drafter
    Drafter
    The problem probably isn't the software but the hardware. The only thing I can think of is to uninstall hardware and reinstall the camera using the driver provided. If this doesn't work send it back to JVC Service. My GR-DV2000u had numerous problems including the input/output box to USB. This piece of excrement has caused me nothing but trouble & hours of fiddeling.
    Drafter
