JVC AV32WFT1 picture ghost?
Discussion in 'General TV Discussions Forum' started by jtorry, Mar 9, 2002.
  1. jtorry
    jtorry
    Nov 8, 2001
    523
    I have a JVC 32 inch flat screen TV and I have noticed that when watching DVDs, when the picture switches to another shot I can still see the previous image for a fraction of a second. Especially when in darkly lit scenes. Is this a problem with the TV?
  2. bob007
    bob007
    Could be the 100hz processing, not a fault, just a side effect.
    I had a Phillips set that was pretty bad, i found if i turned all the extra processing off like DNR, Black Stretch etc it helped and was hardly noticable.
    With DVD you should be able to get a cracking picture just by having a decent scart and adjust the picture by the TVs colour, contrast and brightness no need for extra processing.
  3. jtorry
    jtorry
    Nov 8, 2001
    523
    the set dosn't have 1ooHz and I have no special picture processing selected.
  4. shez316
    shez316
    Feb 25, 2002
    117
    +3
    I have the 28WFT1 and have no such problem.
  5. jtorry
    jtorry
    Nov 8, 2001
    523
    Would brightness and contrast levels make a difference? what are yours set to?
  6. shez316
    shez316
    Feb 25, 2002
    117
    +3
    I messed about with the Brightness and Contrast but still noticed no ghosting? I have my DVD connected via S-video scart 2. Have you tried a different lead?
  7. jtorry
    jtorry
    Nov 8, 2001
    523
    I have tried both SVideo and RGB and the problem still persists.
  8. jtorry
    jtorry
    Nov 8, 2001
    523
    Do you think this problem would warrant a replacement TV? I have tried a different DVD player and the problem is still the same.
  9. shez316
    shez316
    Feb 25, 2002
    117
    +3
    My last suggestion was going to be "try another DVD player." As you've already done this, I would suggest getting a replacement. This ghosting effect is NOT present on my WFT1, therefore it is not a normal feature of the set.
  10. jtorry
    jtorry
    Nov 8, 2001
    523
    This sounds like the problem I am having.
    A property of phosphors which determines how long they continue to emit light after the electron beam has been removed. Short persistence phosphors give high bandwidth but emit less light and may be seen to 'flicker'. If persistence is too long then moving images leave a 'smear' or 'trail' on the display. This can be an advantage in certain applications e.g.radar.
