JVC AV32R4SK HELP Please
Discussion in 'Televisions' started by ehowland, Jan 16, 2005.
  1. ehowland
    ehowland
    Bought a JVC AV32R4SK from Comet yesterday. All seemed ok last night after setting it up.
    This morning, turned it on and it takes 2 mins. from pushing the power button to getting a picture. Is this normal? (This is the same from standby too)
    Secondly, I have no sound from BBC1, BBC2, ITV or Ch4 - picture perfect but no sound.
    I have a DVD, Video and a Freeview box, each connected, via a scart lead and these work perfectly - sound and picture.
    I have gone throught all the settings, but no still sound from the TV or Subwoofer on the TV channels. Comet helpline is closed today. HELP :lease: .................
  2. ehowland
    ehowland
    Anyone ...... :mad:
  3. kbfern
    kbfern
    Aug 17, 2002
    17,042
    Wolverhampton
    +5,124
    with the video connected and viewing channels 1,2,3 &4 (terestrial tv) are you getting sound and vision?
    I was thinking of one of these sets for a present for my parents and was going to purchase one from comet in the next couple of days.Whats the picture quality like, did you pay £449, seems a good spec tv for the price just hope that the set does not suffer from any quality/fault issues.
    If you have sound on dvd,video and freeview it must be a setting that is wrong in the menu or something similar
  4. GaryB
    GaryB
    Nov 12, 2002
    5,341
    St Albans
    +1,264
    It should start in under 10 seconds. Try unplugging whatever you have connected to EXT2 and then see if the set starts up properly.
  5. ehowland
    ehowland
    kbfern
    The picture is perfect, just no sound on analogue channels.
    GaryB
    Will try taking out the EX2 scart. Why might this make a difference?
  6. GaryB
    GaryB
    Nov 12, 2002
    5,341
    St Albans
    +1,264
  7. kbfern
    kbfern
    Aug 17, 2002
    17,042
    Wolverhampton
    +5,124
    ehowland
    did Garyb's solution work, do you now have sound on all scarts and tv, and does tv come on quicker.I would appreciate an answer as we are ordering our set today.
    I am collecting our set from comet would you be so kind as to let me know the box dimensions so that I can check I can get it in my car.
    Hope your set is now working Ok and that you are pleased with your purchase.
  8. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi Gary,
    Does this apply (in general) to connections made to Ext 1 or is this use of pins 10/12 generally 'restricted' to the second scart connection? Thanks for previous explanation of this fault/cure - very useful. Regards, yt.
  9. kbfern
    kbfern
    Aug 17, 2002
    17,042
    Wolverhampton
    +5,124
    collected our set today from comet and used scarts 1 & 3 only, connected cable box / vcr using scart 1 & dvd using scart 3. Sound and picture ok through scart or watching via tv.
    Tv comes on within 10 seconds everything aok.
