JVC AV32R25 Speaker Buzz
Discussion in 'Televisions' started by YtramC, Jan 20, 2003.
  1. YtramC
    YtramC
    I wonder if anyone can help me with this one before I contact JVC, my three month old AV32R25 has developed an annoying speaker buzz. Muting the sound leaves a very audible buzz and when watching at low volume can clearly be heard (and is very irritating). Turning off the speakers from the menu stops the buzz completely!
    Any suggestions would be gratefully received!
  2. GaryB
    GaryB
    Nov 12, 2002
    5,345
    St Albans
    +1,266
    This is not a known problem and sounds sounds like a fault. You should contact you retailer first.
  3. YtramC
    YtramC
    An update on this buzzing, just as mysterious as how the buzzing started, it has stopped! No buzzing at all for the last few days! I'm going to keep listening to see if ir re-occurs!
    Marty
  4. JohnTres
    JohnTres
    Sep 2, 2002
    50
    I had the same buzz from the centre speaker - even on mute. I'm afraid it used to come and go so you may find that your buzzing comes back.
    Swapped it for a new one which luckily did not buzz (but had a blurred picture so got swapped for a Sony).
    I'd get it swapped if I were you.
    John
  5. YtramC
    YtramC
    John
    Thanks, I'll keep an eye on it for the next couple of weeks and if it persists will contact the store for a replacement. Having read a couple of other threads on buzzing speakers it seems that electrical interference from extension leads and other applicances can cause the same effect. I'm going to make sure the wife and I don't plug anything into the same wall point for a few days just in case!
    Marty
