Jvc AV28X4S
Discussion in 'General TV Discussions Forum' started by alfonze-1, Sep 1, 2004.
  1. alfonze-1
    alfonze-1
    Does anyone have the Jvc AV28X4S or Jvc AV28X4 model, I am trying to find out whether it supports progressive scan, (I know it doesnt support PAL but not sure about NTSC). Also can someone tell me if it has a component input on the back of it I cant seem to find anywhere that says it does or doesnt.
    Cheers :lease:
  2. scrapbook
    scrapbook
    Jan 12, 2002
    7,435
    +553
    no componet inputs, and jvc website makes mention of progressive NTSC material.
    Not quite sure how that works personally!
    For more info have a look at the JVC website
  3. Sjekster
    Sjekster
    Anybody has some info on how the progressive scan on this tv works? I have a dvd player from pioneer which can output a progressive scan signal through component. I can't find any info on the JVC tv however which says it has component in (maybe it's shared with one of the scarts?) :confused: :lease:
