Jvc AV28X4S v Sony KV28CS70S
Discussion in 'General TV Discussions Forum' started by ace420, Jul 25, 2004.
  1. ace420
    ace420
    hi ppl,
    i still seem to be struggling choosing a new tv i've narrowed it down to these two,Jvc AV28X4S or Sony KV28CS70S, i was originally after a sony kv28fx68, but it is now dicontinued. both the tv's have 100hz and 3 scarts. however the jvc is a lot cheaper than the sony. you guys have the knowledge, :lease: help me out. i basically want a tv under £600 with atleast 2 rgb enabled scarts. possibly 100hz. by the way is the picture on the sony better than the jvc?
  2. philangst
    philangst
    Mar 27, 2003
    128
    Didn't know the Sony KV32FX68 had been discontinued? You can still get it at the moment. Try this link: -here
  3. drljames
    drljames
    Jul 17, 2004
    367
    Telford
    +11
  4. cerat
    cerat
    According to the manual on the JVC site, the 28 inch X4 doesn't have geomagnetic correction control. So, going on the comments on this forum, along with my recent experience with 28-inch R25s and R4s, the question is, do you mind watching a display (esp. DVDs) that has picture tilt (anywhere in the region of 5-10mm)? Sorry to bang on about this, but you might be grateful that I did!
  5. ace420
    ace420
    so cerat what you're basically saying is that i should go for the sony then? as for the sony kv28fx68, i know some sites still do it, but i would like to purchase from JL, in order to get myself a five year warranty. cerat as for this picture tilt problem is that common on all jvc's especially the x4, or just some sets?
  6. cerat
    cerat
    Hi ace
    I can’t give a positive view on the Sony model, because I haven’t seen it. I can give a negative view on the JVC on account that doesn’t come with geo-control. Unless the manufacturing quality on the X4 is better than on the R4, you would have to assume that the X4 likely comes supplied with the picture tilt problem that appears common to the R4s. The fault cannot be corrected: there is no service menu adjustment, and the scanning coils are bonded onto the tube. I suspect that many people even don’t notice the tilt because most times they’re watching a panoramic/full screen on broadcast material. On the other hand, if you were making your purchase from JL there would be no problem in returning the set, even if the picture tilt were within the 5mm tolerance level set by JVC. Have you thought about the 28D40? I believe that this model does come with geo-control. The model's a bit pricey, but since JL stock it, you could do a bit of research and get a price match.
