JVC AV28X10EKS No video or audio
Discussion in 'TVs' started by geerthi, Oct 5, 2005.
  1. geerthi
    geerthi
    Please help JVC AV28X10EKS On screen display Ok but no video signal found through ariel or scart - checked all my best still confused. Tuner seems ok. I could not pinpoint the point of missing signal. Screen is just blank apart from on screen menu display. Thanks for all.
  2. JayCee
    JayCee
    Jan 20, 2004
    20,337
    Lanarkshire
    +1,953
    Do you have sound?
    Is the set out of or still under warranty?
  3. geerthi
    geerthi
    Thanks JayCee, set is out of warranty. no sound because of no video signal. But I assume sound system is ok because I can hear hissing noise. Thanks.
  4. JayCee
    JayCee
    Jan 20, 2004
    20,337
    Lanarkshire
    +1,953
    Input a known/good VCR or DVD via scart and report back what you get?
  5. geerthi
    geerthi
    Hi, Thanks but no signal getting through scart either. No change in screen when I input a DVD signal through scart. Thanks again.
